Crank no start
Working on a Yale GP050VX 2012
I have installed a new cam sensor/distributor assembly. I'm getting system voltage to the sensor and the signal wires are good to the ECU. The system will not fire. Will a scanner or computer be required for further troubleshooting? The LCD on the dash is not legible. Thanks.
  • Posted 17 Dec 2025 00:44
  • By Joshua_Fruge
  • joined 17 Dec'25 - 1 message
  • Louisiana, United States
I am thinking this is a Mazda engine in it. I know this sounds stupid but did you check to make sure the timing belt did not break that would cause no spark to the plugs. If so check all fuses and relays in fuse box.
  • Posted 1 Jan 2026 11:08
  • By Scott_
  • joined 16 May'21 - 334 messages
Scott
Lithium Storage
Leading China-based developer and manufacturer of Industrial Lithium Batteries.
UN Forklift FGL18T
SMV (Konecranes) 4632CC5
Lithium Storage
