Cracked flexplates
Has anyone seen cracking flexplates in the Doosan G20SC-2 LP with a Mitsubishi 2.4 engine. Second one cracked. We checked the flywheel, mount, and converter for being true. Lasts about 1,200 hours. Cracks @ the flywheel mounting bolt area.
  • Posted 20 Aug 2010 01:52
  • Modified 3 Sep 2010 12:11 by poster
  • By roadtek
  • joined 4 Dec'07 - 123 messages
Patience and a 12pt stubby wrench.
  • Posted 17 Nov 2011 01:32
  • By roadtek
How did you get those 2 bolts in the middle of the trans., on both sides. There is no room to get at them. The 2 that face the opposite of the rest.
  • Posted 17 Nov 2011 00:38
  • By jim_v
  • joined 26 Aug'08 - 61 messages
  • Michigan, United States
No diff problems, but we did find the problem. After researching the history of the truck we found it had been in an accident. Soneone ran into a steel collumn with the left fork - broke the trunion. So after we pulled the trans, we pulled the mounting plate ( like a spacer between the trans & block). It was tweaked. When we bolted the trans up it would load it to one side - causing stress on the flexplate.
  • Posted 17 Nov 2011 00:30
  • By roadtek
Was wondering if you had any diff. problems with this truck? I have one that broke the teeth on the ring and pinion. Have any idea why that would happen? Thanks, Jim
  • Posted 17 Nov 2011 00:21
  • By jim_v
edition #1237 - 3 July 2025
Load Lifter LABORER-SERIES6.000LB
Flesherton, Ontario, Canada
Mobicon 2T
East Syracuse, United States
Saratoga, United States
Columbia, SC, United States
