Convert 3ph charger to 1ph
YUASA EXIDE WORK HOG
M/N W3-18-680
S/N W196759
Part# W3-18-680B
Charger is wired for 3ph. Is there a way to rewire to operate on 1ph. 220/240Volt.
  • Posted 19 Jan 2012 07:11
  • By richardb69
  • joined 19 Jan'12 - 3 messages
You can not run a 3 phase charger on single phase period. The only thing that you can do is to buy a phase converter which changes your single phase power to 3 phase.
You can run a single phase charger on 3 phase however by only only using two wires plus the ground.
  • Posted 20 Jan 2012 00:19
  • By duodeluxe
  • United States
duodeluxe
can be done, not very economical to use
  • Posted 19 Jan 2012 13:55
  • Modified 19 Jan 2012 13:56 by poster
  • By toyzilla
  • joined 29 Mar'10 - 175 messages
the boss
  • Posted 19 Jan 2012 08:09
  • By richardb69
IF it has 3 transformers you rewire them so they each are powered by the 2 legs of the single phase. Make sure the voltage taps for the transformers and contactor are set for 240.
  • Posted 19 Jan 2012 08:08
  • Modified 19 Jan 2012 08:14 by poster
Thank You, any ideas would be appreciated, trying to impress the boos
  • By richardb69
I believe you would have to change the transformer in the charger to do this
  • Posted 19 Jan 2012 07:35
  • By kevin_t
Yes you can. But, I can't tell you how.
  • Posted 19 Jan 2012 07:24
  • By johnr_j
"Have An Exceptional Day!"
Unicarriers FD80-2
SMV (Konecranes) 4632CC5
