Controller replacement
Do controllers for the current models (3 phase drive) require any programming or tuning upon installation? Controller replacement did not solve our problem, and I want to rule out this possibility before further experimentation damages the new controller.
Employer is somewhat reluctant to initiate a service call given our highly modified stackers and remote location. If that is the only way to go, we will do so, just trying to find some basic info first.
Thanks in advance!
  • Posted 20 Feb 2016 02:33
  • By nmsu
  • joined 20 Feb'16 - 1 message
  • New Mexico, United States
There are about 11 setting for the traction controller. If the replacement controller is set to the same parameter values you should be ok but you mentioned you have a modified machine so it may be that adjusting some controller settings is required. Did you copy the settings in the old controller? that would be a good reference point to start from.
  • Posted 25 Feb 2016 03:38
  • By Roibeard
  • joined 2 Mar'10 - 335 messages
  • Dublin, Ireland
Taylor T520S
Maxlion R2B25LI
Linde Material Handling
