contol valve
slow to lift when warm ,pump hits 250 bar at relief
sometimes wont lift at all ,lower the mast then it will lift, levers are good and calibrated,lsg shoows coils being sent voltage ,saftey shows voltage ,when it wont lift there is not any attempt to lift ,engine does speed up
any help out therethanks
  • Posted 10 Mar 2023 06:02
  • By Ed_Becker
  • joined 10 Mar'23 - 2 messages
swapped control valve with one from another lift truck ,works great, what do we look for in this control valve to repair
thanks
  • Posted 14 Mar 2023 05:06
  • By Ed_Becker
is dis problem only on lift ?\
  • Posted 12 Mar 2023 02:05
  • By michel_v
  • noord holland, Netherlands
