Continental F163 engine noise
We have a Clark C300Y40 with an F163 Continental engine. After the engine has been running for about 5 minutes, a metal to metal sharp type of noise develops. The noise only happens when the engine is at an idle. Once it is accelerated even slighly above an idle it goes away. We removed the valve cover to so if a valve or lifter was stuck and they are fine. Could it be a timing, idler or hydraulic pump gear problem? Any ideas??
  • Posted 23 Jan 2009 23:19
  • Discussion started by duodeluxe
  • United States
duodeluxe
Wentzville, MO, United States
Ottumwa, IA, United States
Harrisburg, SD, United States
Taylor TX330S
USD159,500
Nagano NUZ090D
edition #1235 - 19 June 2025
