Come out of gear. Forward or reverse.
Hi, I recently purchased a CY50 serial number Y50B-134-2085. The motor runs great but the lift comes out of gear when its challenged. A small rock will prevent the machine from moving. Its full of ATF and i don't smell clutch burning, but its acting like it. Please help, Im new to these forklifts and not sure what to look for.
Thanks
  • Posted 17 Nov 2016 08:55
  • By AKmike
  • joined 17 Nov'16 - 3 messages
  • Alaska, United States
No change. Machine still comes out of gear if it goes up a small hill or even climbs through a small pot hole.
  • Posted 22 Apr 2020 01:53
  • By AKmike
It is also common that the springs in the slave cylinder break and will not let the arm attached to the salve retract and engage the transmission.
  • Posted 18 Nov 2016 22:55
  • Modified 18 Nov 2016 22:56 by poster
Ok, Ill check it out.
  • Posted 18 Nov 2016 09:31
  • By AKmike
Check the left master cylinder to see if there is free travel. On top of the trans control cover there should be a cylinder housing with a brake line going to it. That is the inching slave, make sure there is zero pressure on this with the left pedal all the way up.
  • Posted 17 Nov 2016 09:59
  • By BREWSKI
  • joined 10 Jan'12 - 1,698 messages
Fishermen in the town of Oostduinkerke on the western tip of Belgium's coast practice a 500-year-old form of shrimp fishing. Known as paardenvisser, the fishermen trawl the shallow waters on Brabant draft horses, pulling funnel-shaped nets to capture the crustaceans.
Leonardo Quintero Stollwerck Leonardo Quintero Stollwerck
Senior manager sustainability, KION Group
General manager, Autoquip
VP and CEO, Toyota Material Handling Australia
President and chief executive officer, Toyota Material Handling Australia (TMHA)
edition #1290 - 16 July 2026
In this week’s Forkliftaction News , Jungheinrich has taken out top honours at this year’s International Intralogistics and Forklift Truck of the Year Awards (IFOY) and Noblelift USA has launched its 10T capacity “beast” of a forklift... Continue reading
