Combo lift, right hand wheel not staying straight?
Hi folks, I have a big yellow combo lift, model:c5000 serial: 13646.
The right hand wheel won't stay straight and keeps drifting off, 99.9% sure it's not electric. Is there a comin fault or an easy way to diagnose this before I order a cylinder??
  • Posted 23 Apr 2012 21:59
  • By uplift
  • joined 28 Mar'09 - 66 messages
  • lincoln, United Kingdom
We ended up putting a new ram, promblem solved, thanks for your replies!
  • Posted 30 Apr 2012 22:23
  • By uplift
The realignment procedure is,
put into sideways mode, then steer fully anticlockwise as far as it will go making sure both front steering rams are fully extended, then put back into forward mode. There is a small valve on the piston of the right hand ram used for equalising the cylinders, this maybe leaking and allowing the oil to cross from one side of the cylinder to the other, worth checking.
Steve.
  • Posted 27 Apr 2012 02:48
  • By steven_w
  • joined 20 Oct'06 - 16 messages
  • Aberdeenshire, United Kingdom
Thanks for the replies guys,
This fault occurs when driving straight, the right hand wheel drifts off to the right. I've stripped the cylinder but I can't see any obvious faults with the seals.
  • Posted 26 Apr 2012 03:58
  • By uplift
how often does this happen?
this is a common problem combilift machines have after changing steering modes repeatedly. Over a period of time the wheels tend to get out of sync and they get misaligned.
There is a trick to getting them back in alignment by putting it in sideways mode, steering the wheels full left, full right, then full left and then back to center. After completing this you can change mode back to forward drive and then back to side drive and the wheels should turn and align correctly then.
if this problem is happening frequently as in like everyday then yes, there may be a cylinder leaking internally. There are tests you can do to check the cylinders but for now i would identify what the problem actually is before ordering cylinders.
  • Posted 25 Apr 2012 10:19
  • By Jplayer
John Player Jr
_________________
LiftOne, LLC
Charlotte, NC
Email: jplayer@liftone.net
Is this happening when the machine is sat over night or for an extended length of time?
You cannot swap cylinders to check as they are different, one is a master and the other is a slave.
We have had cylinder glands come loose but you would always have the fault then.
If it is over night it is the cylinder bleeding back, there is no cure for this it is just something they do when left, what you do is put the truck in 90 degree mode steer lock to lock then put back in straight, it should then line up. Later machines have this procedure on a label in the cab.
If the fault reoccurs when using the truck it is something else.
  • Posted 25 Apr 2012 06:13
  • By danny_k
have had cylinders seal fail before could swop over to test check wheel stop bolts are ok , think it needs rhs leg to buffer to overcome valve to send drive wheel round ? if thats not happening , combilift are very helpfull with tech info
  • Posted 25 Apr 2012 04:51
  • By trevb
  • joined 10 Jan'12 - 157 messages
  • avon, United Kingdom
monday is the longest day
The origin of "love" as the score zero in tennis is debated, but two main theories prevail. One suggests it's derived from the French word "l'oeuf" (egg) which resembles the shape of the number zero. The other proposes it's related to the Dutch word "lof" meaning "honour" as players might be playing for honour when scoreless.
F. Uchiyama
edition #1239 - 17 July 2025
As part of Forkliftaction’s 25th anniversary celebrations, we have dug into the archive and, over the next year, will be highlighting a carefully curated selection of historical stories we have published over this time... Continue reading
