Combilift C6000:
Combi will not drive.
The combi will change in all directions but will not drive. Checked the proper fuses and all are good. changed the parking brake button still wont drive. Tested the brake valve at the rear wheel and front right wheel and they are working. Checked the plc board and it points to the 4 port diverter valve, dont think its getting power. any ideas
  • Posted 14 Jun 2025 01:32
  • Discussion started by Nic_Olson
hi there are many things that can stop the unit driving but if you have directional change working just a question make sure brake light is operating on the dash when you put handbrake on i have had trouble with the switch under the inching pedal which also activates the brake just a thought richard from combilift will help you when he sees the post
rule of thumb dont over think the problem some times its easier than you think
  • Posted 15 Jun 2025 17:43
  • Reply by skyreach
  • Victoria, Australia
reach for the sky
Your Focus
Jefferson, WI, United States
St. Louis, MO, United States
Johnston, IA, United States
