Codigo de falla 522762-4
Me pueden apoyar con este código por favor y a qué se refiere 522762-4
Littoral Translation...
Can you help me with this code please and what does 522762-4 refer to?
Please use English Language
  • Posted 8 Aug 2024 08:52
  • Modified 8 Aug 2024 15:29 by administrator
  • By Sofo
  • joined 17 Mar'23 - 3 messages
  • Mexico
David G. C.
Sofo,
Ignition 3 voltage is low. First check battery voltage when trying to crank engine. Check fuses 6 and 7 to make sure they are reading battery voltage. Swap relay 1 with relay 5 and see if code changes. This means the relay has failed. Remove each connector at the fuse box and check for corrosion and good connections. Good Luck.
  • Posted 19 Aug 2024 23:27
  • By Fishmech
  • Virginia, United States
The term 'Genuine Leather' is not used to reassure you that the product is made of leather, but rather to indicate that the lowest quality of leather is used.
ORDER PICKING
FLEET MANAGEMENT
HIGH-CAPACITY FORKLIFTS
CHARGING INFRASTRUCTURE
SAFETY SOLUTIONS
October 28, 2026 - Melbourne, Victoria, Australia
November 3-6, 2026 - Shanghai, China
ORDER PICKING
FLEET MANAGEMENT
SAFETY SOLUTIONS
