Codes G4, 5J, 5G
I am looking for some ideas for the G4, 5J and 5G codes. I have tried a couple different batteries. It will drive for a little bit and then throw the 3 codes. Sounds and feels like the break is dragging when it throws the codes and the break and drive motor will heat up quickly. Any ideas or advice would be greatly appreciated.
  • Posted 26 May 2022 23:26
  • By Jbartho
  • joined 26 May'22 - 1 message
  • Oregon, United States
Jacob
If you've had weakened or bad batteries the problem is control power. Look closely at the relay board...
  • Posted 8 May 2023 01:34
  • By TLI2
  • joined 8 May'23 - 1 message
check the short frame possible steer motor G5 possible amp
  • Posted 28 Apr 2023 14:33
  • By JKPAINTER
  • joined 26 Jul'17 - 73 messages
most likely brake its bad or the DM its binding, that drags the voltage. Lift the truck, remove the brake assy. check the motion of the motor.
  • Posted 10 Feb 2023 02:26
  • By max_h
  • joined 28 Sep'17 - 13 messages
Ncn 85TH
Ncn 85TH 2014
Toyota 8FG25
