Schaeff W30SRS:
codes 65R 88
found diode bad replaced both traction diodes lift one ok swapped positions of traction amps removed steer motor put in brushes and cleaned hooked up all motors to battery they all will run sent controller and lift amp to flight systems put both back in code 88 if you stand on deadman wait for warn1 you get code 65Rremoved battery cleaned rollers
  • Posted 22 Feb 2013 05:09
  • Discussion started by BarrenForklift
  • Kentucky, United States
had diodes backwards they changed pin numbers on them code 88 hyd pump was shot motor current during self test not right i suppose installed new pump 88 gone
  • Posted 13 Mar 2013 00:14
  • Reply by BarrenForklift
when you sent in the amps to be checked (repaired) you also sent in the display unit as well? the display unit is also part of the logic circuit, everything runs through that and in my experience the display is very sensitive to voltage spikes and will get damaged if your not careful. I've replaced a few of these in the past.
  • Posted 22 Feb 2013 21:50
  • Reply by swoop223
Code 88 is: Lift motor current not present/Diode Failure
Says to check the 600 Amp lift fuse(blown) and Test the diode for the lift amplifier(shorted or open)
Those are the only two things in the troubleshooting section for this code.
  • Posted 22 Feb 2013 20:36
  • Reply by kevin_t
we did blow a fuse while testing still have a nagging code 88
  • Posted 22 Feb 2013 10:33
I would check to make sure your power fuses are not blown,i have seen a fuse look and test/ohm good but once it gets some current running thru it it goes dead.....also check the condition of your cables to make sure there are no bare spots that are shorting to frame when the motor is trying to run. Especially check you A1 and A2 cables from the Right traction amplifier to the motor(code 65R) Check the continuity of the motor windings in the right motor,check for an open winding condition
  • Posted 22 Feb 2013 08:51
  • Reply by kevin_t
edition #1234 - 12 June 2025
