CODE T4
Hi, I need help I have intermittent problem with the code T4 and the lift stops working. 420-c35qm raymond model.
  • Posted 11 Nov 2011 05:34
  • By tecforelec
  • joined 21 Dec'10 - 10 messages
  • P.R., Puerto Rico
grego thank you very much for your help, I could solve the problem, replace the VM and delete the code t4. thanks
  • Posted 16 Nov 2011 09:50
  • Modified 16 Nov 2011 09:51 by poster
  • By tecforelec
  • P.R., Puerto Rico
T4 - priority bypass sol4 open cct
Run test a81
Should see, 0a at neutral, 1.15 at lift and lower for auxiliary.
Check coil and wiring, otherwise r/r vehicle manager
  • Posted 15 Nov 2011 05:52
  • By grego
  • joined 15 Nov'11 - 12 messages
  • Alberta, Canada
