Linde (& Baker) H40D:
Code T236
Ser#H2X394S03558 Code T236 No drive operation, Hydraulics work but no engine throttle control. Flywheel sensor was replaced.
  • Posted 8 Mar 2013 06:47
  • Discussion started by joe_o
I am also having that fault code T236 but mine there's no drive at all so doesn't rev up but the hydraulic works,any idea please,thank you.
  • Posted 14 Oct 2016 18:29
  • Reply by dido_e
  • Gauteng, South Africa
Sounds like it could also be chipped fly wheel tooth
  • Posted 24 May 2015 06:14
  • Reply by edward_m
Hi Joe,
What clearance have you set the actual speed sensor to>>>>
should be 0.5mm up to + 0.3mm
The only way to check the function of the sensor is using motor data software on laptop.
  • Posted 13 Mar 2013 02:38
  • Reply by micky_h
  • South Elmsall, United Kingdom
Yes we found hydraulic controller plug was missing. Now code of T248 speed sensor. Installed new sensor but we still have the code when engine hits Hi rev it drops in creep mode until you recycle key switch. We think it may be the ring gear teeth, hard to check inside of gear.
  • Posted 12 Mar 2013 07:10
  • Reply by joe_o
Hi Joe,
T236 = Travel direction switch all inputs open
e.g. Coding connector missing, sounds like you have wiring issues.
Regards
Micky
  • Posted 12 Mar 2013 03:49
  • Reply by micky_h
Toyota 8FGCU25
Flesherton, Ontario, Canada
Maxlion MTF30-45-2WD
Your Focus
edition #1234 - 12 June 2025
