code numbers
We are having trouble with side-shifter/push-pull. When we use the s/s or push-pull levers the unit stops operating and code numbers 54-1, 64-1 and CB-1 appear on dash and a beeping noise starts. We turn the key off and recylce the key switch and hand brake. The unit will operate in lift and tilt but as soon as the side-shifter or push-pull lever is activated the contactor tips close brightly and the unit stops working. The contactor tips are new. Any ideas?
  • Posted 8 Aug 2006 03:26
  • By art_k
  • joined 10 Feb'05 - 1 message
  • New Jersey, United States
Ia,m having same problem
  • Posted 1 Mar 2016 04:36
  • By Markserv
  • joined 1 Mar'16 - 3 messages
Hey did you ever figure out that error code problem Rich
  • Posted 2 Mar 2008 03:39
  • By rich_k
  • joined 30 Oct'07 - 108 messages
Rich Knack
It may sound strange but I would check the battery. Using s/s and p/p draws more current than lift
  • Posted 2 Nov 2007 12:14
  • By rich_k
do you still need help with your 4wheel electric?
  • Posted 15 Sep 2007 22:38
  • By erik_h
  • joined 12 Sep'07 - 18 messages
  • Tennessee, United States
Toyota 3FD100
UN Forklift FBT18NQZ1
