code H1-4 Toyota 7FBEF18
Hi ,
I have a code H1-4 on this Toyota 7FBEF 18 12039 2004 with joystick lifting and i need to now what this code is and how i repair this.
Truck drives good and lifting. Sometimes the truck stopping with lift down and goes out.
Regards
  • Posted 27 Jan 2010 19:03
  • Discussion started by gc_d
  • Zuid-Holland, Netherlands
Regards gc_d
Hi Franco c,
I replacet the lift lever potentiometer and match the settings withe the forks 500 mm up the floor and i match all the settings to ok so the truck is good working.
Thanks for all help..
regards
  • Posted 14 Mar 2010 01:10
  • Reply by gc_d
Regards gc_d
H1-4 The anomaly is caused by the neutral position of the potentiometer lifting.
The calibration with the aid of the function analyzer - I / O monitor 3.
If the adjustment is likely correct fault CPU.
Hello Franco
  • Posted 14 Mar 2010 00:19
  • Reply by franco_c
  • Bologna, Italy
Your lift lever abnormal
Its possible to calibrate hopefull it works
otherwise you must replace and callibrate again
Regards
John.
  • Posted 31 Jan 2010 22:19
  • Reply by johngen
  • NB, Netherlands
Jospeh E Creed Jospeh E Creed
CEO, Caterpillar Inc
Secretary general, European Rental Association
Chairman of the Board of Directors, UgoWork
UN Forklift FBR25NQC3
JLG 260MRT
JLG 260MRT 2016
Flesherton, Ontario, Canada
May 21-23, 2025 - Guangzhou, China
September 16-18, 2025 - Dar Es Salaam, Tanzania
edition #1229 - 8 May 2025
