code E32
turn ign on code E32 shows in hour meter box runs ok for a while then starts to loose power- is this code for overheating as unit is very dirty also where is the scan port for these units -will have to steam clean the unit to find motor its that bad-any info on this code would be great-worked on other cat lifts but this ones new to me
  • Posted 31 Dec 2013 12:01
  • By oldywan
  • joined 20 Jan'13 - 21 messages
  • Saskatchewan, Canada
get a new temp sensor sender. the e32 should have gone away from showing on the dash, when the engine was running, as soon as the engine was cool.
  • Posted 5 Jan 2014 04:21
  • Modified 5 Jan 2014 04:21 by poster
Thanks for the info-cleaned the machine and checked the coolant cleaned out rad-did the pedal dance and took bat cable off but still wont clear code-any suggestions
  • Posted 5 Jan 2014 04:01
  • By oldywan
nobody got to this yet? gee
yes E32 is overheat stage1
if the radiator is dirty blow it out
make sure coolant is up in the reservoir and radiator
the scan port?
well the diagnoser plug will be in 1 of 2 places
older units it is behind the right step kick panel cover
newer units (tier2 and up) it is underneath the cup holder on the wire harness.
if your looking for the OBD connector on older trucks it is in the wire harness under the dash at the cup holder, same with newer trucks.
  • Posted 4 Jan 2014 01:59
Airman ENCL045
Manitou M50-4
Bolzoni SpA (Group HQ)
