Code e06-1 no throttle
Just replaced engine harness on this truck, had multiple codes and bad wires. Only codes left are e 01-5 and e 06-1. Have had the o2 sensor code on same model truck but it would still run and drive. The throttle motor code is harder to diagnose whether it is the etc or the ecm. Code only comes up after starting and immediatly goes into limp mode. No throttle response at all. Any help or directions would be appreciated.
  • Posted 5 Sep 2018 07:10
  • By Buttscratcher
  • joined 7 Aug'18 - 2 messages
  • Oklahoma, United States
Just had this issue pop up this morning on our 8FGCU25. I went about looking into the carb before it enters the intake manifold and found large deposits of soot where the throttle flap meets the walls. After cleaning it out there was a small clearance that the soot was obstructing and the forklift has been idling for 20 minutes and is purring like a kitten. Hope this helps someone.
  • Posted 24 Oct 2023 01:37
  • By Randy_Gouveia
  • joined 24 Oct'23 - 1 message
I'm having the same issue did you find a fix
  • Posted 12 Feb 2020 05:14
  • By Stephen_Ladeau
  • joined 11 Feb'20 - 4 messages
Stephen ladeau
Hawker Powersource, Inc.
