Mitsubishi FGC30N:
Code E-43
I have a Mitsubishi FGC33N 22 modal year that has a code E-43 can anybody enlighten me on what the cure is for this, all help will be greatly appreciated.
  • Posted 13 Apr 2023 00:42
  • Modified 13 Apr 2023 00:43 by poster
  • Discussion started by Buddy2000
  • Illinois, United States
Just adding on to scott_s post. Dirty air filter, dirty lpg filter in lock off, leaking fuel injector, leaking assistant injector, dirty/bad mass air flow sensor, vacuum leaks, intake leaks, dirty/bad O2 sensor, plugged catalytic converter just to name a few. Alot of things can give this code. But like he said check of its running to rich or to lean first.
  • Posted 13 Apr 2023 09:13
  • Reply by BLey
Code E-43 air fuel ratio malfunction truck is running lean or rich check alpha reading and see what the computer is doing adding fuel or taking it away check for vacuum leaks check converter pressure check fuel injector good luck.
  • Posted 13 Apr 2023 06:33
  • Reply by Scott_
Scott
edition #1228 - 1 May 2025
