Raymond 10F40L:
code C28
hi, i have a c28 code in a walkie palett model 102t-f45L, unfortunatelly have no serv.man. do somebody can give some advise about it? i heard it is just a inproper turn off procedure.
  • Posted 3 Sep 2008 11:38
  • Discussion started by roldann
  • nuevo leon, Mexico
The most common thing is that the red on/off toggle switch is turned off when you are turning the truck on with the keyswitch or the keypad on the handle. I have had a few trucks get this code when trying to lift. It turned out the truck had one bad battery in the battery pack. If the truck has a battery pack with four 6 volt batteries in it you can test them one at a time with a volt meter. Leave them all connected and check the voltage right at the terminals one battery at a time while operating the lift or travel and see if the voltage drops way down. I have seen this more with the Champion/GNB sealed batteries but have also seen it with the non sealed ones. Good luck.
  • Posted 16 Sep 2008 13:05
  • Reply by kurt_k
  • Wisconsin, United States
St. Louis, MO, United States
Jefferson, WI, United States
Johnston, IA, United States
VETTER Forks, Inc.
