Code c21 -FET hydraulic .operation failure .Hydraulic Fet module error
How do l fix the above mentioned error code.
Background : the machine was invoved in a minor accident which damaged few cables to the main fet board( two cables shorted) , through visual inspection to the board was a damaged or burnt single transistor.The forklift showed codes c22( sensor current - current hyd) and b12(sensor current travel). From that point not a single operation was working except just showing those codes with the key on and other auxilliaries such as horn and lights.
I then repaired damaged wiring ,insulating naked parts it was a very small portion to replace whole loom.
I replaced damaged main fet board and the contactor.
After that all previous codes were cleared and l operated the lifting levèr ,then boom error code c21.
Is there anything else lm missing
  • Posted 31 Dec 2019 17:27
  • By WtnNeta
  • joined 31 Dec'19 - 1 message
  • Zimbabwe
Wtn
edition #1290 - 16 July 2026
In this week’s Forkliftaction News , Jungheinrich has taken out top honours at this year’s International Intralogistics and Forklift Truck of the Year Awards (IFOY) and Noblelift USA has launched its 10T capacity “beast” of a forklift... Continue reading
Toyota 8FD45
Unicarriers FHGE35T5S
September 8-9, 2026 - Barcelona, Spain
November 11-12, 2026 - London, United Kingdom
February 8-10, 2027 - Mumbai, India
