Code C-35
Any one know the fault? No drive forward or reverse.
  • Posted 1 Mar 2018 09:54
  • Modified 1 Mar 2018 09:55 by poster
  • By Horse
  • joined 11 Jan'11 - 38 messages
  • Wisconsin, United States
Jeff Bykowski
Code C35
Code Title - Brake Switch (Arm Angle Proximity Switch) Error
Operator Display - C35
System Response - Normal travel controls are disabled. The truck responds only to activations of the
Emergency Reverse switch if the traction motor is rotating in the tractor-first direction.
Alarm Sounds - Yes (3 beeps, once, when error code is generated)
Reason - The brake switch (arm angle proximity switch) is out of adjustment or damaged giving a false indication that the brake is engaged. At the same time, the traction motor is detected rotating.
Tests to Run - Test the brake switch (arm angle proximity switch) and wires.
How to Clear - Apply the brake and have the switch adjusted or replaced.
  • Posted 27 Sep 2018 23:09
  • By darek_s
  • joined 17 Jan'13 - 27 messages
Kai von Berg Kai von Berg
Muncie, IN, United States
