Code AL 11
I have a jack that has been faulting out with a code AL-11
One of the four batteries tested bad and has been replaced.
Battery pack volts show 25.5 volts, I have no lift nor travel.
  • Posted 6 May 2015 09:30
  • By DarkMark
  • joined 6 May'15 - 4 messages
AL-11 is failure to charge controller capacitors. Check brake coil for short, also line contactor and hydraulic solenoids. check field cables and all wiring for shorts. Could also be a failed controller.
  • Posted 6 May 2015 22:31
  • By BREWSKI
  • joined 10 Jan'12 - 1,698 messages
edition #1297 - 3 September 2026
In a move intended to provide Pakistan with a basis on which to compete with its global peers as a modern trading economy, Hutchison Ports Pakistan will spend $76m on a major upgrade and electrification of the cargo-handling equipment at its Karachi facility... Continue reading
ATEX MIRETTI GROUP
Miretti Explosion Proof Systems for Material Handling: for over 50 years, "Ex Atex Safety in Explosive & Hazardous Areas".
Phytoplankton create at least half of the world's oxygen production, despite amounting to only about 1% of the global plant biomass. They also respond rapidly on a global scale to climate and environmental variations, so are often used as indicators of marine health.
