Code 8L Brake engaging even when deadman pedal is pressed
I got code 8L Brake Feedback Current out of range...I checked the resistance of the coil and is good 10ohms...According to the next step is to get B+ from PF2-2 and TP4 then I get 36+....could the VM really be bad?
  • Posted 2 Apr 2011 05:18
  • Modified 2 Apr 2011 05:39 by poster
  • By fredz0003
  • joined 25 Feb'11 - 69 messages
Raymond Action
Will do thanks a lot.
  • Posted 4 Apr 2011 22:20
  • By fredz0003
Raymond Action
hey Fred.
8L is usually the ckt to VM. The deadman switch has to engage right away when pedal is depressed a small amount. If it's tow low, like half way down pedal stroke, you get code 8L. The VM wants to see DM switch then travel on the hall effect sensor. If DM switch is intermittantly open, or the small harness directly attached to it, or harness break anywhere between VM and DM switch, it codes out 8L. A weak spring or loose pedal bushings will give 8L too. Give a good tug on the small 2 wire harness at DM switch to check for broken wires.
Always replace the DM switch if in doubt and the spring/bushings as needed.
  • Posted 4 Apr 2011 07:52
  • By EasiTek
Hitachi HX64B2
Hangcha CBD15
China
USD1,600
edition #1237 - 3 July 2025
Nagano NUZ090D
Toyota CORE-IC-PNEUMATIC-FORKLIFT8FGU25
Flesherton, Ontario, Canada
Columbia, SC, United States
East Syracuse, United States
Saratoga, United States
