Code 845 after lift cylinder seal change.
Changed Left Lift cylinder seal...after lowering mast onto supporting block. started truck back up and codes out. tried manually tripping hydraulic contactor...will run pump but wont allow lift to raise.
  • Posted 21 Dec 2017 06:02
  • By JMyers
  • joined 21 Dec'17 - 1 message
  • Indiana, United States
Once you mis-stage the mast, you have to go into service mode.. calibrate....C5 valves....lift minimum. Then raise forks off of blocks and chains. Turn off and re-key. Lower forks. Then go back in and erase codes. Don't forget to bleed out the air in the cylinders.
  • Posted 27 Dec 2017 13:48
  • By Ifixit
Ice 24INCH-AUTO-SCRUBBER
USD6,396
UN Forklift FB25N1QZ1
Sue Tomic Sue Tomic
USD6,396
Sue Tomic Sue Tomic
USD6,396
