code 64 on toyota
Can anyone tell me what a code 64 is on a toyota 7fgcu30 serial#60604 Thanks
  • Posted 4 Dec 2008 01:35
  • Discussion started by PR2005
  • Illinois, United States
Yeah, or somethings is jammed in there by the tilt cylinder, Thanks Cooter
  • Posted 18 Dec 2008 07:52
  • Reply by rich_k
Code 64 is a Tilt solenoid 1 abnormality.
The tilt solenoid should be aprox 10 ohms at the solenoid.
If you want to check the complete circuit remove connector 1 from the the SAS controller should be 26 pin connector. Check from pin 13 light blue wire to pin 24 white with a black stripe.
  • Posted 18 Dec 2008 06:23
  • Reply by Cooter
  • Indiana, United States
Thanks Rich
  • Posted 11 Dec 2008 07:20
  • Reply by PR2005
Code 64 is for the SAS it is either the height switch, switch on right side tilt cylinder or pressure switch in middle of mast. Rich
  • Posted 5 Dec 2008 08:41
  • Reply by rich_k
June 24-27, 2025 - Lima, Peru
August 1-3, 2025 - Coimbatore, India
September 16-18, 2025 - Dar Es Salaam, Tanzania
Architect Gustave Eiffel originally submitted his design for the Eiffel Tower to Barcelona but the city rejected it for aesthetic reasons. As we know, he had more success in Paris, however, his plan was far from popular at the time.
