Raymond SA SWINGREACH:
code 57
Occasionally, I get a code 57 at start up. All I have done is clean connectors with no results. Any ideas?
  • Posted 15 Feb 2012 13:32
  • Discussion started by Liftdoctor
  • Indiana, United States
If Code 57 appears when
exiting Diagnostic Mode,
verify that the firmware chip
on the Operator Display
Interface Card is at version
2005 or higher. If not,
replace the Operator Display
Interface Card. For chip
location, see Figure 7-57 on
page 7-31.
This code can occur in two
ways:
* Truck operates with Code
57 displayed.
* Check continuity of
wiring harness from
display interface to
Carriage Manager
JP3-JPC18.
* If continuity is OK,
Display Interface Card.
See "Operator Display
Interface Card" on
page 7-81.
* Truck does not operate
with Code 57 displayed.
* See "Troubleshooting
Communication Fault
Codes (50-series)" on
page 5-20.
* Check for shorts to frame.
https://forkliftmanual.com/forklift-manuals/raymond-sa-sb-swing-reach-truck-manual
  • Posted 15 Jun 2025 07:44
  • Reply by marksmith
  • United Kingdom
forkliftmanual.com
Hello colleagues I have this same failure change of vmc and display and still throws this error they had some solution thanks.
  • Posted 10 Jun 2025 16:26
  • Reply by Geoanzu
  • Colombia
G&M herramientas logística s.a.s
Had another unit with a code 57. Found out someone had plugged the main mast and mini mast weight sensors in the wrong spots, they were swapped.
  • Posted 13 Oct 2018 01:07
  • Reply by tyler_d
Is it a BIG 57 that fills the whole screen?
  • Posted 5 Oct 2018 08:53
  • Reply by Service_T
  • Kansas, United States
After you go thru all the steps in the book for code 57, everything this topic has listed and if you still have a code 57 check the heartbeat at IL1 on the platform manager. If no heartbeat think about swapping out the VFC and the display card.
  • Posted 5 Oct 2018 05:26
  • Reply by tyler_d
I agree with joe d. Just a couple more things for you. Check for shorts to frame and correct if found. The cable for the display manager sometimes breaks where it is tie wrapped to the r/s arm outter shielding may look good but ohm it out with handle up/down. Also you may just need to run a configuration download. (Key off. Depress both deadman and lift select button, key on and push lift select 3 or 4 times) when download is done code 57 will be displayed. Rekey and download is finished.
  • Posted 12 Aug 2012 02:30
  • Reply by stam
50 series codes are information errors. The easiest thing to look at is your over mast cables. Are they starting to spiral. Ohm the cables from the tractor manager to the carriage manager and check for shorts between wires as well.
  • Posted 15 Feb 2012 23:42
  • Reply by joe_d
Ain't nothing I can't fix but a broken heart and the break of day!
JLG G9-43A
JLG G9-43A 2007
Flesherton, Ontario, Canada
Hangcha CPYD32XW71F-C
edition #1234 - 12 June 2025
Johnston, IA, United States
Jefferson, WI, United States
St. Louis, MO, United States
Lift Technologies Inc.
UN Forklift FD35T
Terberg YT220
