code 57, 43, and 24
Ok so one of my crown sp3020-30 stock pickers had to be towed back to my shop the other day. The operator indicated that he and another operator were trying to see whos truck had more power by butting up to each other and going full throttle. Well I had a wrench and it indicated a code 57. my book states "this status code is displayed when the voltage input to control card plug PCZ positions 13 and 12 are wrong polarity." Symptom: Forward or reverse contactors open momentarily, close and open again (PMT TRIP). it says possible cause "sensor wires reversed in plug PCZ. I checked all of that and everything was ok. Another cause is stated at "check green and yellow wires in postions 12 and 13 of plug. they are in the right positions. What readings should I have at these locations with my meter?? it states that power wires may be reversed. that's not the case here. so all connections are were they should be.
I even swapped traction cards because I thought that it just wasn't reading the current sensor. but I have the same issue. code 57. Im stumped on this
any advise would be greatly appreciated.
  • Posted 4 Jun 2019 05:31
  • Modified 4 Jun 2019 05:31 by poster
  • Discussion started by Busch
  • United States
You might need to replace the Oscillator Card, if you can remove it smell it for any burning odor.
You need to remove & test the SCR's that attach to the Heat Sink.
And you need to test the Capacitors.
What you described tells me that more than 1 component is damaged.
It will be much essier for you if you have a crown service manual.
I hope those fools got punished for what they did.
  • Posted 8 Jun 2019 19:30
  • Modified 8 Jun 2019 19:34 by poster
  • Reply by LaGrange
  • Missouri, United States
Strong in mind, Strong in Health.
update.
I found that the F13 fuse was bad. I had a higher reading on one side of the fuse and a lower reading on the other side. Problem is now that I have travel, but I'm at a creep speed and when I go to plug from forward to reverse or vise versa it wrenched out and I get a code 57.
Any ideas?
  • Posted 4 Jun 2019 23:18
  • Reply by Busch
  • United States
Taylor TX330S
USD159,500
Manitou M50-4
Harrisburg, SD, United States
Ottumwa, IA, United States
Wentzville, MO, United States
UN Forklift FBT18NQZ1
TCM FD115-3
