Cat Lift Trucks (& Caterpillar) EP20KT:
Code 53
Can anyone help me with this problem code and 50 have replaced steering soensor and main board when you turn the key on the code stays out for a while but when turn a corner slow the code comes back up.
  • Posted 22 Nov 2007 02:42
  • Modified 18 Dec 2007 02:28 by poster
  • Discussion started by Smokey
Thank you
dcollins131@knology.net
have you got the switches set right in the new board?
  • Posted 29 May 2009 22:15
  • Reply by fixit
  • bury, United Kingdom
First check up sequence of signals from a steering sensor control. Tell the E-mail I shall send you the circuit.
At us the similar case with new EP20KT -was a factory defect of a back steering reducer , it was necessary drill a steering sensor control and adjust it in the necessary position.
  • Posted 29 Feb 2008 23:08
  • Reply by aleksander_k
  • Moscow, Russia
edition #1228 - 1 May 2025
Louisville, KY, United States
Dubuque, IA, United States
