Code 524225-4 Transmission
I keeping getting code 524225-4 everytime the truck starts. Anyone have a manual or something to help me figure out what is causing the code?
  • Posted 6 Nov 2013 07:52
  • By Madfish
  • joined 16 May'12 - 22 messages
  • Missouri, United States
Hi everyone
I had also same Problem can you determine which sensor I need to swap on?
Big help
Thanks.
  • Posted 10 May 2023 11:27
  • By jonathan_l
  • joined 8 May'18 - 6 messages
  • Jeddah, Saudi Arabia
Im a hero
For your reference, the diagnostic manual is over 2000 pages long. Too large to send digitally. If you need a manual you will need to contact a local dealer.
  • Posted 27 Jul 2018 07:18
  • Modified 27 Jul 2018 07:19 by poster
  • By BREWSKI
I had this code on my truck also. After doing a lot of digging around, mine turned out to be a wiring issue to the sensor. The insulation on the output wire from the sensor, had cracked and split, where the wires entered the wiring harness. Moisture was causing a very minimal short to ground. It seems to me these sensors are very sensitive to ground shorts. Took all the plastic covering off the harness and used brake cleaner to clean everything up. Taped it all back up and the truck has been running ever since!
  • Posted 20 Jul 2018 22:57
  • By calvin
  • joined 14 Jul'16 - 19 messages
  • Illinois, United States
It was the sensor. I spent 2 days on it and they finally told me they had the code about 2 weeks earier and found no transmission fluid in it, so they filled it. Once I cleaned the sensor out it worked fine. spent about a week hunting down a manual just for a clogged sensor.
  • Posted 3 Dec 2013 01:55
  • By Madfish
DTC 524225-4 - Transmission Forward 1 Pressure OORL
The sensor is probably bad. Swap the fwd and reverse pressure sensors. If the code changes to a 524223-3 (reverse sensor) the sensor is bad. If it stays with the same code, there's a problem in the harness or with the computer.
Email me if you need more info (click on my screenname)
  • Posted 6 Nov 2013 11:40
  • Modified 6 Nov 2013 11:41 by poster
  • By justinm
The use of "hello" as a telephone greeting is attributed to Thomas Edison. He is said to have suggested it as a simpler alternative to other greetings, such as "Do I get you?" or "Are you there?".
Columbia, SC, United States
East Syracuse, United States
Saratoga, United States
JLG G12-55A
Crown RD572513TT6860R
