code 31
Working on rider jack dont have service manual. Unit does not lift or travel, brake releases when moving handle down. Can any one help with info on code 31, thanks much appreciated.
  • Posted 28 Jan 2015 15:47
  • By All Lift Tech
  • joined 3 Oct'10 - 57 messages
code 31
Condition
Controller has lost communication with the control handle card.
Truck Response
No Traction
Possible Causes and Test Procedures
1- Insure the cable is connected to the J2 Plug on the controller.
2- Verify all pin connections are tight and making contact.
3- Verify correct connector wiring.
4- Check continuity of the wires running from the controller to the control handle logic card.
Verify continuity while rotating the control handle arm from side to side.
5- Check for control handle wiring grounded to the truck frame.
6- Check for correct operation of the control handle logic card.
Use handheld programmer to verify signals from the control handle logic card are being received by the controller.
7- Replace controller
One of us is probably right here
posting a truck serial number is always more helpful that just throwing out guesses based on a mere description, an error code and partial model number, and no serial number. :o)
  • Posted 29 Jan 2015 12:57
Thanks Nero will do,
  • Posted 29 Jan 2015 12:32
  • By All Lift Tech
All Lift Tech,
I think this code means the driver of the main contactor is open or short circuit. possibly a dirty connector. or wiring damaged.
Check the wiring to the main contactor clean the connectors and check the fastons are tightly connected.
Turn truck of and restart truck.
If no fault found and fault alarm persist then the problem lies in the module.
Regards Nero
  • Posted 29 Jan 2015 07:45
  • By NER045
Michel Denis Michel Denis
