Raymond 550-OPC30TT:
Code 2H
I am getting an intermittent 2H code when hitting bumps. I thought it was a loose connection somewhere but everything i looked at is tight and has good readings. 2 months ago I was getting this code upon turning left or right. I replaced the wiring harness and speed sensor and everything was fine for about 2 months. Now i am getting this code again. It does not code out all the time it is infrequent. I have tested everything on the I-19, I am getting rpm readings on the display, and all connections tested good as described in the book.
I am at a loss here. Any ideas?
  • Posted 10 Mar 2020 01:00
  • Discussion started by Busch
  • United States
Never assume, assumptions are the mother of all ****ups. -Busch-
have either of you found a solution? I have two done with same problem. both 18yr model 7500 reach trucks.
  • Posted 27 Jul 2021 21:51
  • Reply by Derek_Smith
  • Alabama, United States
"if opportunity doesn't knock, build a door." - Milton Berle
Did you ever figure this out?
  • Posted 25 Mar 2021 11:04
  • Reply by Dan_Woes
Linda Häkkilä Linda Häkkilä
Dubuque, IA, United States
Louisville, KY, United States
