code 28
Anyonr here have see code 28 on this machine? When I put steering at maximum right I can forward but no reverse. When I put steering at maxnimum left I can reverse but no forward. I have made some primary check but if someone have experimented this problem and can help me I will save time. Thanks
  • Posted 1 Nov 2016 00:01
  • By mechanicmaster
  • joined 12 Jun'14 - 15 messages
  • Quebec, Canada
Christian
I'm not sure if that code has come up but i have had that problem before and unit was getting confused on what motor to run and what direction to run it. Book points to logic card and or h bridge. when i had that type problem the steering sensor was out and also on another unit the plate for the steering sensor was loose.
  • Posted 9 Nov 2016 01:40
  • By Deuce
  • joined 27 Jan'16 - 26 messages
  • Michigan, United States
Ancient Egyptian civilization lasted for so long - over 3,000 years - that by the time of the New Kingdom (c. 1550-1070 BCE) Ancient Egyptian archaeology was a career option.
Yale Lift Truck Technologies
