Code 28
I have a unit that code 28 comes up intermittantly. Once the truck is shut down and restarted everything works ok. Does anyone know what this code refers to?
  • Posted 23 Jun 2009 13:03
  • By Jenn
  • joined 27 Oct'08 - 8 messages
  • Alberta, Canada
How do you perform the test for the encoder? Do you need a laptop or is it an on-board test? Thanks!
  • Posted 12 Sep 2019 02:26
  • By Otterwork
  • joined 1 Dec'18 - 3 messages
  • Manitoba, Canada
for code 28, verify the encoder pully is tight on shaft and does'nt spin. also, make sure the encoder is free to swivel. do not tighten the mounting screws as the belt may jump the teeth. play in the encoder is ok. If your connections are all ok, and you tried another known good encoder, the system card or VFC may need replacement.
Code 29 is also no encoder counts while drive is commanded. You need to go into INPUT tests I16 and manually turn encoder to verify it counts from 255 to zero as you turn it. Again, make sure gear is not spinning on shaft and belt is free to spring back. possible other cause are System card, VFC.
  • Posted 2 Aug 2011 01:04
  • By EasiTek
Did you ever resolve the original code 28 issue? I have the same code but my belt/gears are good and swapped the encoder with a known good one and still the problem presist. Anyone have any other ideas?
  • Posted 21 Jul 2011 04:45
  • By BenH
  • joined 17 Aug'09 - 27 messages
hi I got code 29 same truck, please any help wellcome.
  • Posted 6 Jul 2011 05:23
  • By VerticalVicDude
  • joined 3 Jul'08 - 6 messages
Thanks for your help
  • Posted 12 May 2010 12:23
  • By Jenn
  • Alberta, Canada
The other way to diagnose is to open up before turning on the key, remove the encoder belt, and then turn on. If the 84 does not come on then you have brake issues allowing the truck to travel as noted above. This is the issue 99% of the time. I would also add that the barkes may need to be bled.. cheaper and faster than replacing the brakes
  • Posted 11 May 2010 23:59
  • By JonG
  • joined 7 Nov'07 - 155 messages
  • United States
code 84, if the truck is jumping upon start up, your brakes are slipping, check the pads or the adjustments to see that they are opening evenly, the top pads tend to wear faster than the bottoms
  • Posted 11 May 2010 10:47
  • Modified 11 May 2010 10:49 by poster
  • By blaine
  • joined 15 Apr'10 - 3 messages
  • Rhode Island, United States
Hi son t, I thank you for your help with code 28 this same unit is now got a code 84 do you know what this is?
  • Posted 5 May 2010 05:19
  • By Jenn
  • Alberta, Canada
  • By Jenn
  • Alberta, Canada
Hi Jenn,
Some reasons could make code 28, anyhow you may need to check the drive belt and pulley of encoder first, they may be loose or bad. Good luck
  • Posted 5 Jul 2009 23:46
  • By son_t
  • joined 27 Oct'07 - 10 messages
  • Vietnam, Viet Nam
Hi Jenn,
  • Posted 5 Jul 2009 23:43
  • By son_t
  • Vietnam, Viet Nam
Steve Nation Steve Nation
Senior solutions sales engineer, Numina Group
President, International Federation of Robotics
VP of Corporate Remarketing, Alta Material Handling
Chief executive officer, Peak Technologies
Hoist Liftruck F180-36BOX-CAR
SMV (Konecranes) 20-1200B
August 19-21, 2026 - Bangkok, Thailand
November 18-19, 2026 - Singapore, Singapore
November 25-26, 2026 - Budapest, Hungary
Chandler, United States
Philadephia, PA, United States
