Yale GLC050VXNGSE085:
Code 2350-3 NO START
Have this machine that will crank over but will not start, only code is 2350-3 "hyd interlock, return to neutral".
It appears that we do not have power to our fuel lock off, any assistance would be greatly appreciated.
Serial # A910V11972F
EDIT: We supplied 12 volts to fuel lock off still wont start...
  • Posted 13 Jul 2018 00:04
  • Modified 13 Jul 2018 00:17 by poster
  • Discussion started by JAYS
  • Iowa, United States
The voltage to the ignition coil is supplied by the ECU. Check all the fuses first. Then you will need a wiring diagram to go any farther.
  • Posted 17 Jul 2018 05:38
  • Reply by BREWSKI
correct
  • Posted 17 Jul 2018 04:01
  • Reply by JAYS
So the truck is cranking but not starting?
  • Posted 17 Jul 2018 04:00
  • Reply by BREWSKI
thank you!
we found the tilt lever is out, if we hold it in correct position where message goes away machine still wont start. any ideas?
we did find out the machine has no spark either.
  • Posted 17 Jul 2018 02:37
  • Modified 17 Jul 2018 02:38 by poster
  • Reply by JAYS
This unit Has mini levers. One of the lever is not centering. The truck will not start until this is fixed.
  • Posted 13 Jul 2018 22:12
  • Reply by BREWSKI
edition #1234 - 12 June 2025
Toyota 8FGCU25
Flesherton, Ontario, Canada
Airman ENCL045
Johnston, IA, United States
St. Louis, MO, United States
Jefferson, WI, United States
