Code 218 randomly???
Hi! I have a crown wave 60 that maybe 1 times out of 3 shows code 218 « call service » with the wrench key icon and the wave won't start up. I have to mess a few times with the hands control, foot control and even restarting it 1-2 times and the code 218 disappears and the wave just start good normally. What could be the issue?
I don't know if it may have something to do with this but some people probably just went too hard a few times with the right door some times ago so now the right door is VERY loose like if you drive with the doors closed and you break sometime the door just open up by itself, like the resistance in the door mechanism is broken if you know what I mean...
Thanks!
  • Posted 28 Jun 2024 04:43
  • Modified 28 Jun 2024 04:44 by poster
  • By Djaztek
  • joined 23 Jan'24 - 84 messages
  • Quebec, Canada
Ok thanks for help
  • Posted 28 Jun 2024 21:58
  • By Djaztek
  • Quebec, Canada
I would recommend replacing the traction command. Part number: 151797-001
  • Posted 28 Jun 2024 21:35
  • By DyslexicNerd_01
  • joined 13 Jun'23 - 228 messages
  • Wisconsin, United States
Analyzer A4.24
Without doing anything its 2.9V
When moving full speed its 1.1V
  • Posted 28 Jun 2024 21:27
  • By Djaztek
  • Quebec, Canada
Thanks will check this out!
  • Posted 28 Jun 2024 05:22
  • By Djaztek
  • Quebec, Canada
Code 218 is a traction command voltage issue. Use the analyzer menu A4.24 to view voltage. With no command it needs to be reading 0.2v and with full throttle in needs to be 4.5v.
Easiest fix is to calibrate C2 and see if that fixes the issue. Typically that only fixes the issue if the voltages above are correct.
If they are greater than 4.8v then you'll have to start testing modules and commands as there are many possibilities as to what is wrong.
Hopefully this helps!
  • Posted 28 Jun 2024 04:58
edition #1280 - 7 May 2026
In this week’s Forkliftaction News , it’s financial reporting season with Hyster-Yale, KION Group and Konecranes all reporting revenue falls for Q1, yet maintaining their forecasts for moderate growth and stable sales volumes for the year... Continue reading
Unicarriers FHGE35T5S
Terberg RT223
Rabbits can see behind themselves without moving their heads. Because their eyes sit on the sides of their heads, rabbits have an enormous field of vision that helps them spot predators from nearly every direction.
