Code 2000-12 canbuss code
Hello gentleman, we are having a small problem on GLC070...engine starts then shuts down after few seconds, does this 2-3 times then runs perfect after 20 seconds or so...we replaced horn assy and oil press switch, those codes went away...we also have no way of clearing the codes or shutting off lite on dash...any help would be greatly appreciated...thanks bill
  • Posted 20 Jan 2017 07:41
  • By Organized
  • joined 15 Jan'15 - 13 messages
Showing items 1 - 20 of 29 results.
I am currently working on a Yale GLP175VX
It's giving me the code 2000-12 I checked everything except I can't find a second termination resistor I found the one on the steering column can anyone help me need to know where the second one goes
Thanks
  • Posted 4 Aug 2021 05:22
  • By Luis_Saenz
  • joined 4 Aug'21 - 1 message
Luis a. Sáenz
I have another lift throwing the same code. It has 46.7 ohms at diagnostic port. Where do I go from here? Any help would be appreciated.
  • Posted 30 Oct 2019 00:39
  • By troy_a
  • joined 5 Apr'19 - 21 messages
  • Arkansas, United States
Can hi is the yellow wire. Can lo is the green wire.
  • Posted 6 Jun 2019 22:05
  • By BREWSKI
  • joined 10 Jan'12 - 1,698 messages
Thanks Brewski! Have another question. Like I said before I am kind of new to this. What do you mean can hi and can lo?
  • Posted 6 Jun 2019 01:47
  • By troy_a
You have a short between can hi and can lo.
  • Posted 1 Jun 2019 05:18
  • By BREWSKI
I only get 6ohms. What could be the problem?
  • Posted 1 Jun 2019 01:19
  • By troy_a
Diagnostic connector is on the right hand side of the steer column. There is a rubber cover over it. Three pin connector. Remove the front cover off of the steer column. The wires you need to test across are the yellow-green. Disconnect the battery before testing.
  • Posted 29 May 2019 03:22
  • By BREWSKI
Where should I check? Sorry kind of new at this.
  • Posted 29 May 2019 00:47
  • By troy_a
2000-12 is loss of Canbus communication. You should get 60 Ohms at diagnostic connector between can Hi and Can Lo. If you get 100 ohms or higher you have an open termination resistor.
  • Posted 28 May 2019 23:48
  • By BREWSKI
I have a yale GLP040S having code 2000-12. The lift has started then quiet starting. Then would not even turn over. Dash would say starter shut down in count down. Then unplug battery for several days now this code pops up. It turns over but not start. Checked the ohms at test plug and they are both over a 100. All fuses look good. What should I check next?
  • Posted 28 May 2019 23:18
  • By troy_a
Unplug the alternator and check for draw. Check to see if there are any accessories added to the truck. If there are unplug one at a time.
  • Posted 8 Feb 2019 00:14
  • By BREWSKI
Hi all, i have a problem with a hyster ft model, draining power overnight. The Tranzorb resistor (68 ohm) is getting hot and when removed the battery voltage gradually climbs, what is causing this to drain battery volts?
  • Posted 7 Feb 2019 21:16
  • By luke_m
  • joined 2 Feb'13 - 97 messages
  • Bedfordshire, United Kingdom
Actually used a different Fluke meter...it is right at 100 ohms
  • Posted 5 Feb 2017 02:35
  • By Organized
That is way too high. should be between 40 and 60 ohms.
  • Posted 4 Feb 2017 07:58
  • By BREWSKI
Getting 375 ohms at the plug now...using top and bottom right pins
  • Posted 4 Feb 2017 07:38
  • By Organized
The test for the transorb is. Connect ohm meter across terminals. The reading needs to be greater than 0.5 ohms, reverse leads and reading should be above 0.5 ohms. Basically you are checking for dead short.
  • Posted 4 Feb 2017 07:21
  • By BREWSKI
Ok thanks so much for your help, it is just irritating to restart the forklift 4-5 times before it runs correctly...
  • Posted 4 Feb 2017 07:19
  • By Organized
Key off. Key on there is a low voltage signal being transmitted so your reading is incorrect. If this only occurs at start up and there are no other problems, I would not worry about the code until it happens while operating. It is nearly impossible to locate this type of problem until it is constant.
  • Posted 4 Feb 2017 07:15
  • By BREWSKI
Is the resistance with key off or key on...key off is 56k ohms...key on is 1.0m ohms
  • Posted 4 Feb 2017 06:16
  • By Organized
Do you know what the readings on Tranzorb resistor/diode should be?
  • Posted 4 Feb 2017 05:49
  • By Organized
Stu Jacover Stu Jacover
Chief executive officer, TVH
edition #1285 - 11 June 2026
Terberg RT223
Hoist Liftruck F180-36BOX-CAR
