Code 123
Got truck with code 123. Access 1 not seeing input. Replaced access one same issue. Getting 7V when no volts are supposed to be there. Continuity from switch wires to access 1 & 3 is ok. Thinking there's a short somewhere, but can't pinpoint. Checked splice 6, still uncertain how that plays a role. I'm getting battery voltage when checking voltsge to frame. I leaning towards battery voltage leaking thru case. If anyone has experienced this or has any advice, please share the knowledge.
Thanks
  • Posted 25 Aug 2022 11:28
  • By marcos_m
  • joined 25 Feb'19 - 114 messages
Yeah I wouldn't get to hung up on your battery voltage to chassis, it's probably just a ghost voltage with very little current, not even enough to light a 5w bulb I'd guess. Simplest way to eliminate and battery voltage tracking issues though is to simply lift out the battery and stand it to one side with it plugged into truck.
I'd check your multi plug connections on the bottom left hand side under the foot plate, they run up to lights and to access 1, they often get that blue corrosion going on inside the terminals, pop the little green plastic retainers from inside the multi plug and make sure they are all nice and clean.
How many hours has it done?
  • Posted 15 Oct 2022 04:57
  • By Forking_Around
  • joined 17 Jun'21 - 43 messages
  • New Zealand
Hyster
