Code -066 is showing
The serial number is TMX250-2486-9597 KF.
The forklift will move about 2 feet before shutting down. It will restart each time. Anyone know what code -066 means?
  • Posted 15 Jun 2022 02:49
  • By jeffg95
  • joined 26 Sep'16 - 9 messages
  • Tennessee, United States
Usually that code is a faulty controller
If it is 066 then master if a 66 slave but I have seen bad drive fuse give same symptom and code check 500 amp fuse first replace it
If still showing code it is faulty master controller
  • Posted 8 Nov 2022 17:20
  • By John_Bradley
  • joined 10 Aug'22 - 278 messages
Jb69
I would bet that the battery is going bad check the cells under load the problem with ac drive trucks the controllers are not forgiving if there is one weak cell the truck will not work not like dc trucks if the battery is weak it will still drive.
  • Posted 19 Jun 2022 10:05
  • By Scott_
  • joined 16 May'21 - 323 messages
Scott
Code 66 is low battery. Check your leakage from positive to body(counterweight)
If its above 5.0 volts. It requires cleaning. Remove battery from unit and isolate.
They creep so you can charge it. Hydraulic cutout is a symptom of low battery.
  • Posted 16 Jun 2022 00:58
  • Modified 16 Jun 2022 01:00 by poster
  • By grant_c
  • joined 12 Aug'16 - 27 messages
  • Manitoba, Canada
edition #1268 - 12 February 2026
In this week’s Forkliftaction News we look at the life and legacy of Manitou Group’s Marcel Braud, who has passed away aged 93... Continue reading
Johan Leveque Johan Leveque
Vice-chair, ALICE - (Alliance for Logistics Innovation through Collaboration in Europe)
Co-CEO, LIS Logistische Informationssysteme (LIS)
Regional sales manager, Battery Builders
SVP business solutions for the Americas, Dematic
The term "Spring", referring to the season, originated in the 14th century as "Springing time", describing how plants "spring" or burst into life after winter. In the 16th century "Springing time" was shortened to just "spring" for the season of new growth.
St. Louis, MO, United States
Louisville, KY, United States
