Code -06 and -74
Good afternoon,
I have a hyster E50XM that stops on occasion when you try plugging. It reads -06 then -74 and locks up and wont do a thing. Thoughtsor suggestions? Contactors are new. I do not have a manual. Thanks i advance everyone!
  • Posted 9 Jun 2020 05:16
  • By torie_m
  • joined 9 Feb'19 - 3 messages
  • Missouri, United States
Thank you! I appreciate the response!
  • Posted 17 Jun 2020 03:27
  • By torie_m
Those codes make it look like you have a EV100 LX system. If so, -06 means the accelerator was pressed with no direction selected.
-074 SYMPTOM
Forward or reverse contactor opens and closes, then opens and can only close by opening and closing the key switch.
POSSIBLE CAUSE
Defective RB contactor.
? Check RB contactor for smoothness of operation
and excessive wear on moving parts.
Intermittent PA6 input.
? Check for loose connections in PA6 circuit from
PA6 to RB contactor A2 connection.
Defective RB contactor coil circuit.
? Check RB contactor coil for proper ohmic value. It
should be 10-14 ohms.
? Check coil connection from PB2 to RB coil (-) for loose connections.
? Check coil connections from battery positive to RB coil (+) for loose connections.
You can get EV100LX documentation from the Flight Systems website.
I'd tackle the -06 problem first. If your directional control circuits are unreliable that could affect the regen braking as well.
  • Posted 12 Jun 2020 01:05
  • By lumberjack
  • joined 27 Jul'07 - 183 messages
  • Maryland, United States
May 20-21, 2026 - Melbourne, Australia
August 19-21, 2026 - Bangkok Thailand, Thailand
edition #1277 - 16 April 2026
In this week’s Forkliftaction News , we look at how automation continues to be an area of rapid advancement for the materials handling sector, as we saw at LogiMAT 2026, but not everyone is convinced of its value - yet... Continue reading
