Code 01 Help
Hello this is my first post
We have a Mits FBC25
Serial AFB2-50388
in our shop. it wont do anything. we are thinking its the pedal. we finally got it to throw a 01 code. can anybody help.
also can anybody help with cross referencing Mitsubishi models and Cat models. thanks
Doug
  • Posted 5 Jan 2010 09:36
  • By offroad72
  • joined 5 Jan'10 - 34 messages
  • Nevada, United States
we are getting a code 65 and 69 on an fbc25k. would you be able to help me with translating this?
  • Posted 23 Dec 2011 16:19
  • By jon_g
  • joined 23 Dec'11 - 1 message
  • Alabama, United States
Status -01 on GE would be no input from seat switch circuit
  • Posted 7 Jan 2010 02:54
  • By carl_v
  • joined 12 Oct'07 - 76 messages
I think this unit uses a GE ev100 controller, and the error codes below 89 will be the same as on any other truck using the same controller setup, code 07 is input too high at tb1
accel pedal mis-adjusted or open in circuit between battery neg and TB1
  • Posted 6 Jan 2010 11:39
  • Modified 6 Jan 2010 11:40 by poster
Hi thanks for the reply. The code we are having the problem with now is 07. we figured out 01. thanks. if you have any info that would be great.
Doug
  • Posted 6 Jan 2010 08:53
  • By offroad72
I can cross the models for you, just ask what models you want to know about, however Cat forklifts and Mitsubishi forklifts used different controllers in the standard electric forklifts.
In both cases, the code 01 is a seat switch not closed at startup.
  • Posted 5 Jan 2010 12:32
  • Modified 5 Jan 2010 12:33 by poster
ROYPOW
Enforcer FD50T-MMA
Toyota 02-8FD25
ROYPOW
