Clark Order Picker model- OP15X, S.N. OP15X-134-9297PM
Good morning sir,
Any body knows how to replace the steer/traction controller card,
no. 154-012-581/004. It this need to calibrate the board, Thanks
for the reply please help.
Thanks,
Rolly
  • Posted 30 Jul 2019 15:25
  • Discussion started by rolly
  • Manama, Bahrain
rollbes2003@yahoo.com
Hello guys,
I buy curtis handheld 1313, but when i connect it on the truck
the handheld cannot get any information in the board even i try
to get the program to the other truck. I want to clarify if this handheld is suitable to this control board or not.
Please help , thanks,
Rolly
  • Posted 8 Aug 2019 00:06
  • Reply by rolly
  • Manama, Bahrain
I try this Curtis model- 1309USB OEM only 4pin soi cannot
Fix to the 9pin plug, if their is adaptor to use this programmer
Is it possible to use.
Please advice,
Thanks,
Rolly
  • Posted 31 Jul 2019 17:28
  • Reply by rolly
  • Manama, Bahrain
you can use the curtis handset to change traction parameters
the steering controller you can not
  • Posted 31 Jul 2019 15:48
  • Reply by swoop223
Good morning swoop23,
I try to fix the diagnostic 9 pin socket to the Curtis programmer
But their is no response to the programmer , I fix the programmer
To the traction controller with 4 pin socket and it is working. So can
I install the parameter in that module coz the steer/traction card have 9 pin socket in the left side of the module.
Please advise,
Thanks,
Rolly
  • Posted 31 Jul 2019 14:25
  • Reply by rolly
  • Manama, Bahrain
when replacing the controller you can use the curtis handset and save profile, then load profile into new controller.
You will need to recalibrate the control handle after controller replacement.
  • Posted 30 Jul 2019 23:35
  • Reply by swoop223
Ottumwa, IA, United States
Wentzville, MO, United States
Harrisburg, SD, United States
Manitou M50-4
Terberg YT222
