Clark Forklift Help
I need some help with a clark. Model cg25cl sn# cl232l 9029 9529kf. It looses throttle response and a light comes on in the dash. I believe it is the check engine light. I hit the accel pedal 3 times and it will flash some codes. They are 12 69 73 74 and 31
  • Posted 21 Dec 2015 01:40
  • By FloydsKnobs
  • joined 11 Nov'14 - 2 messages
  • Kentucky, United States
Did you get this repaired? Code 12 is the start of the code string. You will always start and end with 12
69 typically will need a software update to correct. 73 and 74 is the fuel mix is going over rich and over lean, the trim valves cant keep up with the changes in fuel ratio. could be the mixer sticking or worn out. And 31 is the engine has stopped running with the key on. You will need a laptop and cables to connect to the SECM.
  • Posted 1 Jan 2016 01:33
  • By Diego_deLavega
  • joined 14 Mar'12 - 14 messages
Briefs United States
