clark c500 forklift
Hello friends, i have a forklift c500 but it has no power going over high surfaces,my first though would the tranny,but no matter how hard you would rev it, no result in climbing. can anyone help on that??
  • Posted 13 Nov 2012 05:10
  • By Bless
  • joined 2 Feb'12 - 8 messages
  • st.andrew, Jamaica
Pleasant Good day to you johnr j, i went back on location to re-access the cmp 25 fork, what was interested is that,after engaging the hindging brake the tranny was still in motion and cripping,so i found out that it was only working as a brake and not disengaging the tranny. so i am asking you if you have theory on the hindging brake or diagram for this type forklift. the serial number is cmp230l-4317-6872-kf model# cmp25l LPG. and sorry i didnt get the chance to check the incline of the hill. Thank you
  • Posted 16 Nov 2012 00:29
  • By Bless
Glad you found the issue & was able to solve it.
  • Posted 15 Nov 2012 07:58
  • By johnr_j
"Have An Exceptional Day!"
john r : i went to the customer yesterday only to find out that it was the hindging brake spool that had stick causing lost of power.
thank you greatly appreciated.
  • Posted 15 Nov 2012 02:35
  • By Bless
Bless: in an earlier post you talk about an Clark CMP 25 having the same issues after you rebuilt the tranny. Is this C500 the same unit? Also what lift capacity is this unit. C500 only means the design series not lift capacity a complete model number like C500-Y50 (for a 5000 unit pneumatic tire) is more meaningful and a complete serial number is also helpful as it contains a lot number which identifies any design changes and year of manufacture. This info is stamped on the truck data plate. If teh data plate is missing the full serial number is stamped in the frame - generally near the RH front drive tire. Also the grade of the ramp is nice info - see my response on your CMP-25 issue.
With this info. you can get a more accurate response.
  • Posted 13 Nov 2012 21:07
  • By johnr_j
Thank you very much point taken, i will go tomorrow to do as told i will let you know the result. must greatful
  • Posted 13 Nov 2012 06:22
  • By Bless
How high does the engine race when fully throttled? If engine operation is ok then it could be a few things- trans fluid level low-tranny worn out- inching spool sticking, brakes sticking or the plug in the torque convertor has fallen out.
The first thing to check is trans fluid level. Dipstick is on top of differential housing, between the dash cowl & the upright. Warm engine to operating temp, tilt upright full forward, set parking brake, put trans in nuetral, keep engine running & pull dipstick. Trans fluid level should be clearly marked. Trans fluid should be bright pink. If needed, add Dextron ATF fluid- the newest version will work fine.
The next thing to check is idle & full throttle rpm in nuetral, followed by the same check in forward, then reverse. When checking rpm in forward & reverse, make sure brakes are fully applied & wheels chocked.
Report back after those 2 checks are completed
  • Posted 13 Nov 2012 05:58
  • By bbforks
Muncie, IN, United States
Elwell-Parker ESI500-36
UN Forklift FD30T-NJM1
MAXAM Tire, Inc.
MAXAM Tire, Inc.
