Clark C25L
I have a Clark C25L Serial # P232L-0185-9593KF. 6000HRS. It has a message on the display, PIN 125/C GND. The engine will turn over, but the coil is not sparking. It has a Mitsubishi engine with a crank position sensor and an unusual ignition coil. It has a Woodward LPG fuel system. I can't find any troubleshooting info for this ignition system. Are there any service manuals available for this forklift. Thanks, GW Ebbs
  • Posted 15 Mar 2017 01:54
  • By gw_e
  • joined 18 Mar'15 - 22 messages
I see it's been awhile, but did you figure it out?
I have the same problem.
Dash reads Pin12S/C GND, no spark.
  • Posted 31 Dec 2024 04:58
  • By Den_Barteski
  • joined 31 Dec'24 - 4 messages
  • Manitoba, Canada
I think this code should read PIN 12 S/C GND. Check the engine shutdown relay and wiring for shorts to ground
Regards
  • Posted 18 Mar 2017 06:34
  • By Tungsten
  • joined 18 Mar'17 - 5 messages
  • Tyne and Wear, United Kingdom
I've brought this forklift into the shop. I can't find any description for the message on the display. Any help would be greatly appreciated. Thanks, GW
  • Posted 16 Mar 2017 01:50
  • By gw_e
Deborah Baker Deborah Baker
Enforcer FLBAXT25
Toyota 02-2TD20
