Choosing a battery
Dear All, I have a request concerning batteries.
How to choose the accurate battery for an electric truck?
is there any formula to help me?
I think that the biggest Ah is the best, but I'm not sure, and I want to know the advantages and inconvenients of a big capacity battery vs.
I imagine that if I choose a 48V - 485 Ah battery, this would need to be charged less often than a 48V - 330 Ah.
Furthermore, as a battery is built to be charged 1500/1600 times, we can imagine that the 48V - 485 Ah would last longer.
But I'm sure that it is not so simple...
Would somebody please be able to explain how to chosse a battery?
Thank you!
  • Posted 26 Apr 2013 00:27
  • By MikBZH
  • joined 26 Apr'13 - 3 messages
  • FRANCE, France
Dear BBForks!
Thank you for your answer which is exactly what I was waiting for! And thank you also to all the persons who take time to answer to this post!
Best regards.
  • Posted 26 Apr 2013 16:04
  • By MikBZH
  • FRANCE, France
I'm assuming you're purchasing a new truck with a choice of batteries? Variables, such as working enviroment, physical size of truck, shift work, etc need to be explored in order to give an accurate answer.
Lifts are designed around an 8 hr shift. Installing a larger A/H battery than needed may mean that the lift needs a charge right in the middle of a shift. If this becomes the norm- overcharging the battery may become prevolent- shortening the life of the battery.
I think that the time spent investigating the advantages of different A/H batteries would be better spent developing a effective charging system that works around the 8-8-8 system.
In smaller operations with limited lifts, the 8-8-8 system is very difficult to follow. Unless a system is in place & followed, overcharging the battery becomes the norm & battery life deminishes greatly.
  • Posted 26 Apr 2013 07:39
  • Modified 26 Apr 2013 07:39 by poster
  • By bbforks
Some new trucks can be had with different size / AH batteries, on certain reach trucks going for the larger AH battery can have an effect on the overall length of the truck.
Something to think about if aisle width is tight when you spec a truck.
If you look on BT forklifts it gives a MINIMUM & MAXIMUM battery weight on the data plate that the truck is rated for.
  • Posted 26 Apr 2013 02:32
  • By Forkingabout
  • england, United Kingdom
The original battery should have a plate or stickewr on the side wit make and model etc. That might be a good starting point. But there is no guarantee it is the original battery.
  • Posted 26 Apr 2013 00:54
  • By Leon_W
  • Tyne & Wear, United Kingdom
Dear Leon_W,
Thank you for this prompt answer!
I still have not purchased the truck, and want to order the most suitable battery.
  • Posted 26 Apr 2013 00:43
  • By MikBZH
  • FRANCE, France
If you are planning to fit a smaller A/H battery than the original you might have to fit some ballast. The truck will have been spec'd with a specific size (A/H) and weight (to act as counterbalance) you need to check manufactures spec. You would get more work time out of a higher A/H battery.
  • Posted 26 Apr 2013 00:32
  • By Leon_W
TCM FD115-3
UN Forklift FD30T-NJM1
