check engine lite on toyota 7fgcu25 4y engiine
How do I retreve the codes
  • Posted 17 Jan 2010 12:42
  • By rebelviper
  • joined 17 Jan'10 - 11 messages
I could sure use a copy of the codes myself if someone can help.
  • Posted 5 Nov 2013 00:37
  • By Forkliftt
  • Louisiana, United States
Steve
steve at forkliftt dot com
Thanks Rick. That did the trick.
  • Posted 1 Nov 2013 06:58
  • By AnDroid
  • joined 1 Nov'13 - 1 message
Thanks for the info rick c.
  • Posted 18 Jan 2010 09:13
  • By rebelviper
by the way you can clear those codes by pulling the TWC fuse or disconecting the battery.
  • Posted 18 Jan 2010 04:43
  • By rick_c
  • joined 30 Jul'09 - 204 messages
Thanks rick c,I have the check engine lite on like you said In your email to me.Do I pull the pin out of the dianostic link connector to retrieve the codes,And can you email the list of codes. Thanks again.sumtermh at yahoo dot com
  • Posted 18 Jan 2010 04:18
  • By rebelviper
you have to spell out your email such as (dot) and (at). the engine light on the right side of the dash shaped like an engine outline has a different way of retreiving codes. post your e and someone will help.
  • Posted 18 Jan 2010 03:50
  • By rick_c
technology: (no user serviceable parts inside)
Thanks ian h, Do you have a list of the codes that you can email me @ [email address removed]? Thanks again for the info....
  • Posted 17 Jan 2010 23:22
  • By rebelviper
Turn ignition on or start engine, remove small link pin in diagnostic plug (under fuse box) all stored errors will now scroll on dash (max of 10 are stored)
Dont turn ignition off until link pin has been refitted or you will put error into memory
  • Posted 17 Jan 2010 20:14
  • By ian_h
  • joined 11 Sep'08 - 149 messages
  • United Kingdom
Toyota launches three new stackers Columbus, IN, United States
Jan Zuurbier Jan Zuurbier
Global CEO, Swisslog
Board member, UKMHA
Strategic advisor, Roboteon
CEO Americas, Hai Robotics
September 4, 2025 - Melbourne, Australia
September 17-18, 2025 - Miami, FL, United States
October 21-23, 2025 - Barcelona, Spain
Orlando area, United States
Tacoma, WA, United States
Highland, IL, United States
Dallas, TX or Lexington, KY, United States
