changing lift chains & wiring loom
Hi, we have a Crown Wav which requires the lift chains, wiring loom & mast guides changed. Can anyone assist with the simplest way of doing this please?
As you are aware, the chains are internally fitted, as is the wiring loom in the mast.
  • Posted 16 Nov 2021 19:51
  • By darryl_m
  • joined 28 Feb'17 - 10 messages
  • Mid Glam, United Kingdom
D Moseley
How do you change the cables? It's never been easy for me.
  • Posted 28 Nov 2021 10:37
  • By 1CrownTech
  • Washington, United States
1crowntechnician@gmail.com
mast cables are a piece of cake
lift chains require dis-assembly
  • Posted 25 Nov 2021 21:11
  • By crownie
  • Victoria, Australia
Thank you 1CrownTech
  • Posted 18 Nov 2021 18:56
  • By darryl_m
D Moseley
If you are referring to the mast cables then you must do a complete disassembly. There is no quick fix. It is a difficult job and I recommend two people.
  • Posted 17 Nov 2021 14:48
  • By 1CrownTech
