changing battery voltages in Toyota 7FBCU15
i got a few trucks currently that are using 36v batteries. I would like to be able to change them over to a 48v battery. I know that you can change it using the Service FUNCTION --> OPTION SET menu, but is there anything I would need to know before attempting this? Are all the components inside the truck able to handle this multi voltage?
please help ! thanks
  • Posted 18 Oct 2011 03:27
  • By digitalpnk
  • joined 2 Sep'11 - 24 messages
By the way, I did not change the lights or horn either, and they all work fine!! so far.....
  • Posted 1 Sep 2012 07:18
  • By sassypants
  • joined 1 Sep'12 - 3 messages
Had the same issue on a 7FBCHU25 truck, I went back to change voltage back to 48v from 36v with no luck. Confused as to why I could change from 48 to 36, but not back to 48 from 36; I went back to the programming section again and again. Finally I found that if I exited the programming at function #6; which happens to be "END" all works just fine. Previously I think I may have just turned off the key or something? to reset out of programming or service functions. Good luck!!
  • Posted 1 Sep 2012 07:17
  • By sassypants
ok i have tried this with a second forklift and same story, get the error code e2-2.
I would like to add that both times the horn and lights weren't changed to 48v before the voltage change over.
anyone got suggestions ?
  • Posted 29 Oct 2011 05:18
  • Modified 29 Oct 2011 07:03 by poster
  • By digitalpnk
Need to check all options are correct or specific to units options per lift. Have seen this once before related to incorrect option set.
  • Posted 19 Oct 2011 12:25
  • By Huckleberry
  • joined 20 Jul'11 - 29 messages
  • Tennessee, United States
I ran the analyzer and it points me to either a harness defect or a thermo-sensor defect
how can I further check which is at fault ?
  • Posted 19 Oct 2011 01:43
  • By digitalpnk
after trying it out with one of the forklifts, i got an error e2-2 motor thermo-sensor abnormality. does that have anything to do with it?
  • Posted 18 Oct 2011 22:54
  • By digitalpnk
You need to change your lights and horn.
  • Posted 18 Oct 2011 22:41
  • By Prentice
SMV (Konecranes) 16-1200C
Morooka MFD20
