Caterpillar GP15K Mitsubish FG15K
When we press simultantly up and tilt working properly if press tilt alone need to increaise RPM. Is someone know what this is mean?
  • Posted 25 Apr 2012 00:47
  • By petko_t
  • joined 28 Sep'10 - 37 messages
  • Sofia, Bulgaria
p.troanski@abv.bg
replace the tilt section of the control valve
:o)
  • Posted 25 Apr 2012 10:35
  • By Jplayer
John Player Jr
_________________
LiftOne, LLC
Charlotte, NC
Email: jplayer@liftone.net
This is probably low hydraulic system pressure. To work the tilt you need quite a high pressure to overcome the lock valves. Increasing the revs will raise the pressure if the pump is worn. Check the system pressure and flow you may need to either adjust it up if you can or replace the pump. You need the correct pressure and flow for everything to work correctly.
  • Posted 25 Apr 2012 05:51
  • By AndyPandy
Muncie, IN, United States
UN Forklift FGL35T
Toyota 8FD45
